using hard IP libraries in cadance simulator
Hi I have created a project where I used different hard IP's like pcie, nios processor,emif etc. So how can I simulate this IP's in my simulation environment. I have gone through the documents and I found from the tool we can create the libraries and then we can use them in the corresponding simulation environment. So in any case do we need to use the verilog files created by the IP. As quartus doesn't generate filelist. So my question is how we can use this IP' to simulate in our simulation environment. if I am using IP libraries it says some files are missing in the list. But if I am using the IP libraries I am not sure how this error is showing the simulation.
NOTE: if necessary we can provide the simulation environment for debugging purpose.
- RichardT_altera
The attached link is a youtube video on how-to simulates using a third party simulator like Cadence.
https://www.youtube.com/watch?v=e0X5KMVt4F8
There is also a simulation user guide in the link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-tp-simulation.pdf
Let me know if you need further help.
- DChak3
Thanks Shyan for replying.
I can able to use hard IP libraries and also able to simulate in cadence.
Now the issue is I saw there is problem with pcie_ptile Avalon st Ip as If i simulate this IP, the simulation stucks in 0.0ns in cadence version use incisive 20.018 .
parameters are gen3x8, 256dp 250mhz.
I tried simulating the example design but there also it shows message as "pcie_ed_tb.dut_pcie_tb.dut_pcie_tb.g_bfm.p_dut_ep.altpcietb_bfm_top_rp.g_bfm.genblk1.rp.inst.dut.inst.inst.maib_and_tile.z1565a.ctp_tile_encrypted_inst.PROTECTED: The downstream component is backpressuring by deasserting ready, but the upstream component can't be backpressured."
and it stops, its not going further to run the test cases which are included in the example design bfm. example design can be simulate with vcs only.
for simulation i used vcs 2019 version. Ip was generated for stratix10 device 1SD280PT2F55E2VGS1 from quartus 19.4.
- RichardT_altera
I have confirmed with the team.
As for now, only VCS simulator is supported for P-tile. Please try VCS instead.
- RichardT_altera
The user guide below could guide you to simulate the PCIE design example.
