jjang
3 years agoUsing Altera PLL make 500Khz or below
When i Using ALTPLL, i Usually make 500khz and below xx kHz Frequency Clock. @ 50Mhz / 100Mhz Input clock. But Cyclone 5, Different PLL IP Core. - ALTPLL → Altera PLL, so it doesn't support fo...
- 3 years ago
just read PLL Intel FPGA IP messages thoroughly. It instructs you to enable physical output clock pararameters to configure cascaded output counters.
jjang
3 years agoAs Clocking and PLL User Guide..
Using PLL Clock (C1, C2. C3.C4), then that can though Global clock.
but to make a Clock as a Logic (such as Counter).. will not connect to Global clock . .isn't it?
FvM
3 years agoHi,
