10 years agoUsing Altera PCI AV-MM DMA IP with custom MSI interrupts
I am researching the necessary elements to create a new design to transfer data from a FPGA based device to a host computer using PCI-e interface. So long, i have looked into the PCI-e Avalon-MM DMA ...
8 years agoHi Guys,
Anyone is successful in generating interrupts using Mailbox registers? If yes, please provide the procedure and the interrupt generation flow. Iam referring to this UG: https://www.altera.com/en_us/pdfs/literature/ug/ug_a10_pcie_avmm.pdf My design uses Arria-10 FPGA Avalon-MM with DMA but with external DMA descriptor controller. I have used the below BARs in the Qsys design: BAR0 -> RD/WR Descriptor Contoller Slave BAR2 -> CRA Slave BAR4 -> On-chip Memory slave I would like to know how to write into Avalon-MM to PCI Express Mailbox Registers (0x3A00–0x3A1F) and PCI Express-to-Avalon-MM Mailbox Registers (0x0800–0x081F) ? Is it through Host Software application or by using any other component in the design? Regards linus_alt
