17 years agoUse DDR2 SDRAM!
I have Dsp development Kit Cyclone II and now I want use Ram of it. Everyone, can help for me? Thanks!
If there are no ready-to-use example designs provided for the Dev Kit (I'm not sure about), try to operate the RAM with the test driver created by the Megawizard when instantiating the DDR2 SDRAM IP core. Generally, follow the design flow suggested by the Megawizard respectively the IP core manual.
Thanks! But you can send for me code write by VHDL use Ram?
same problem here, an example VHDL code would be interesting :p
--- Quote Start --- If there are no ready-to-use example designs provided for the Dev Kit (I'm not sure about), try to operate the RAM with the test driver created by the Megawizard when instantiating the DDR2 SDRAM IP core. Generally, follow the design flow suggested by the Megawizard respectively the IP core manual. --- Quote End --- Hi FvM, do you know how to store values on SDRAM using DSP builder??? Please I do really need your help. Thanks ismagine - Altera_Forum
Asking the same question 10 times won't get you more answers
i agree, please create a single new thread instead of bumping so many old ones
--- Quote Start --- Hi FvM, do you know how to store values on SDRAM using DSP builder??? Please I do really need your help. Thanks ismagine --- Quote End --- FvM? any suggestion?
