17 years agoUSB 2.0 core problem
Hi all, I am having some troubles with the USB2.0HR core from SLS corp. I am using the USB2.0HR version 2.2 on Quartus II 8.1. I successfully created the NIOS II sopc and loaded into the...
16 years agoI actually have a question for you instead of an answer :), I have Cyclone III which has a USB connector that is used as you know to upload SOF, debug, etc. With the SLS core are you using the same "connector"? or do you have another external USB connector attached?
As I am a beginner I was wondering how my final design would look like, I mean when I move it from the starter kit to an actual hardware as a product, would I just use a USB connector and the core will do the job, or do I still need other things to connect to? Finally (sorry) how much that USB core cost? or is it free in the SOPC? Thanks in advance for your help.
