11 years agoUniPhy DDR3 IP Instantiation in Custom Top-Level HDL Module
I have a problem with uniphy DDR3 IP instantiation. If I use IP core's top-level hdl module (I mean, ddr write/read controller is inside the IP core's top-level) then DDR3 works. But if I create a new hdl module and use it as a top-level, instantiate IP core in this new top-level module then first read data always is 0xAAAAAAAA and it is wrong. Do I need to do something special to use uniphy ddr3 IP core in my custom top-level like some modifications in pin_assignments.tcl/timing.tcl tcl files? Thank you, Ali1 Reply
By the way, it can be useful following informations:
- Quartus version: Quartus II 64 Bit, 14.1.0 Build 186 - Target Device: Arria V GX Starter Kit (http://www.altera.com/products/devkits/altera/kit-arria-v-starter.html) - DDR3 SDRAM Controller with UniPHY version 14.1
