16 years ago[TSE] how have the datas from fifo tse ?
Hi, I need some help about triple speed ethernet (tse) to receive and transmit datas. I have paid for IP-TRIETHERNET + IP-NIOS + IP-TCPIP-NIOS. The altera support and commercial contact told m...
16 years agohi
Those utilities are not mandatory. They help you to manage mac and ip addresses and store them into nv memory. For test purposes you can simply define fixed addresses. Regarding the fact you say you can't telnet, do you mean you can't either ping? Or you can ping but you can't connect to telnet port 23? I recommend you start with dhcp disabled and use a well known fixed ip address. Cris
