16 years ago[TSE] how have the datas from fifo tse ?
Hi, I need some help about triple speed ethernet (tse) to receive and transmit datas. I have paid for IP-TRIETHERNET + IP-NIOS + IP-TCPIP-NIOS. The altera support and commercial contact told m...
16 years agoHello Cris,
so I test my jump to "RAMPROG_BASE + OFFSET 0x230" and all is ok I test too my jump to "RAMPROG_BASE" and option "enable_alt_load_copy_exceptions" disabled in my bsp and all is ok. Now,I want to launch the "simple socket server" like nios II ide example project : - compilation is ok (i just disable the flash using). - but I have a error message in debug rs (I put my capture.txt file) So i don't undersand because i paid for IP-NIOS , IP-TRIETHERNET and IPSW-TCPIP-NIOS (for nichestack license) So why I have this error how can I obtain a "simple socket server" example with my license (I use triple speed ethernet in gmii mode too). ? thanks for helping Cordialy, Ben
