12 years ago
Triple speed ethernet IP core don't receive the RGMII data?
I use the triple speed ethernet IP core with an external PHY Device, the first picture is shown as my test block diagram . Transmiting part works normally, however, There is no data on the avalon-ST side while the RGMII receive interface is transmitting data. that is , some data can be captured at point "a" by using signalTap II, but nothing comes out of MAC IP 2 and the receive counters of IP core is zero.
Why has this happened? ? what should i do now?
Furthermore, I made an experiment with block diagram 2. The receive count value of MAC1 equals the transmit count value of MAC2. I can see that the link LED is light and the activity LED is blinking. This messages indicate the ping request packets(that is ARP request packets) is transmited correctly. but no response at the side of PC1. Take the previous experiment into consideration, I suspect these packets don't received by MAC layer of PC2.
What caused this phenomenon? what should i do next?:confused:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8065
https://www.alteraforum.com/forum/attachment.php?attachmentid=8066
    --- Quote Start ---
    Since your error is 4-bits wide, and since RGMII is a 4-bit wide DDR bus, I think you need to look closer there.
    Is the problem something simple like you didn't add the timing constraints for the 2nd port? Double check for timing violations anyway.
    --- Quote End ---
    Bit 7 to 4 of CRC-32 field of every received packet becomes a "4" while all other bits is exactly correct. How timing violations could cause such constant error? And, there is still an error after adding some timing constraints to RGMII interface.
