12 years agoTriple speed ethernet IP core don't receive the RGMII data?
I use the triple speed ethernet IP core with an external PHY Device, the first picture is shown as my test block diagram . Transmiting part works normally, however, There is no data on the avalon-ST ...
12 years ago --- Quote Start --- Since your error is 4-bits wide, and since RGMII is a 4-bit wide DDR bus, I think you need to look closer there. Is the problem something simple like you didn't add the timing constraints for the 2nd port? Double check for timing violations anyway. --- Quote End --- Bit 7 to 4 of CRC-32 field of every received packet becomes a "4" while all other bits is exactly correct. How timing violations could cause such constant error? And, there is still an error after adding some timing constraints to RGMII interface.
