K_Crocker's avatar
K_Crocker
1 year ago
Timing for PLL clock PLL_RECONFIG~FMAX_CAP_FF
Each PLL instantiated in my design has a PLL_RECONFIG~FMAX_CAP_FF clock that isn't constrained. Can I constrain these clocks, and, if so, what frequency value should I use? TIA for your answer!
  • K_Crocker's avatar
    K_Crocker
    1 year ago
    Hi Richard,
    The design is quite large, so I can't share it. But to the point, the error is within the Reconfigurable PLL IP block. I think it has to do with the strange timing of the "phase_done" signal, which I believe I have accounted for after carefully reading the user guide. I was hoping that you might have some special knowledge from seeing this condition before.
    So, that said, I think I'll false path or underconstrain the "clock" to get around the issue and close out this request. Thank you for your help.
  • RichardT_altera's avatar
    RichardT_altera
    Which device are you using?
    Kindly share your design by archiving the project (Project > Archive Project) so that I can investigate it further.
    Richard Tan
    RichardT_altera
    Do you able to share the design with us?
    Richard Tan
      K_Crocker
      Hi Richard,
    RichardT_altera
    Noted. If you encounter any further issues, feel free to submit a new case for support.
    You may also consider creating a simplified design to replicate the issue.
    Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
    Richard Tan
