Timing for PLL clock PLL_RECONFIG~FMAX_CAP_FF
- 1 year ago
Hi Richard,
The design is quite large, so I can't share it. But to the point, the error is within the Reconfigurable PLL IP block. I think it has to do with the strange timing of the "phase_done" signal, which I believe I have accounted for after carefully reading the user guide. I was hoping that you might have some special knowledge from seeing this condition before.
So, that said, I think I'll false path or underconstrain the "clock" to get around the issue and close out this request. Thank you for your help.
Do you able to share the design with us?
Richard Tan
Hi Richard,
