timing_error_for_pll_afi_clock_on_ddr3_ip_controller
Just look into the screenshot that you provide, when I try to compile the design and load the PD, I see that you left your avalon pipeline bridge as dangling.
Any reason for that? You can actually connect this pipeline from your CPU.data master to Avalon_pipeline_bridge to TC timing to increase the pipeline for you to close the timing. I would suggest you download one of the example design in the NIOS II in the design store to see how the connection look like.
As you can see above, there are quite a lot of red module that prevent me to make modification of your design for timing closure. Can you let me know what are the setting that you use or the _hw.tcl script location for your custom module?
Hi Ken,
unexpectedly that mm_bridge master connection is removed. actually it will connect to custom rtl avalonport. That part i have connected.
hw.tcl file is located in rtl directory and i have generated from ipx command only .
for ddr , i will create another thread seperately.
But i do have timing violation for pll div clk .
so please look into this also.
- KennyT_altera2 years ago
Hi Sermaswathika,
What I means is your mm_bridge master need to be connected in order to have a better timing. You may take a look into this design example https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/horizontal/exm-tightly-coupled-mem.html , it show how the pipeline bridge was connected from NIOS II to the periheral subsystem. You may need to do the same as well.
I do not see the rtl directory that you have in the zip files, can you send it to us?
My reported failure is different than yours,
Can you download the design example https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-examples/horizontal/exm-tightly-coupled-mem.html and make sure the connection and module comparable compare to your design. After making the changes, zip the design with the RTL directory and send it back to us to review.
Kenny Tan- SERMASWATHIKA2 years ago
Contributor
Hi Ken,
Thanks for sharing the reference. I have implemented the pipeline bridge for other peripherals and ethernet separately. Still timing violation is there.
I could not be able to zip all files as it takes large memory size and i cannot attach in this forum.
i have attached the archive project which size is acceptable in this forum.
