SERMASWATHIKA
Contributor
2 years agotiming_error_for_pll_afi_clock_on_ddr3_ip_controller
Hi Team, I am checking the design with ddr3 interface, nios processor and other interfaces also in cyclone v gx device(5CGXFC5C6F27C7). I have given memory clock as 400 Mhz(ddr3 ip parameter setti...
RichardT_altera
2 years agoTry reduce the number of logic levels to 2-3 by adding pipeline register (this will add latency in your design).
As higher logic level will increase delay on the critical path.
You may checkout this video on @16.49 minute marks
https://www.youtube.com/watch?v=UGGkKZylJBo
Richard Tan
- SERMASWATHIKA2 years ago
Contributor
ok i will check this and let you know
