10 years agotime limited sof not generated when using Frame Buffer II IP
I want to evaluate the Frame Buffer II IP block, but no time limited sof file is generated. The assembler shows the following message: Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores. Warning (115005): Unlicensed IP: "VIP Clipper II(6AF7 0115)" Warning (115004): Unlicensed encrypted design file: "C:/Users/berkelr/Workspace/hmc_project/vid_sys/synthesis/submodules/alt_vip_vfb_sync_ctrl.sv" Warning (115004): Unlicensed encrypted design file: "C:/Users/berkelr/Workspace/hmc_project/vid_sys/synthesis/submodules/alt_vip_vfb_wr_ctrl.sv" Warning (115004): Unlicensed encrypted design file: "C:/Users/berkelr/Workspace/hmc_project/vid_sys/synthesis/submodules/alt_vip_vfb_rd_ctrl.sv" When I use the Frame Buffer or Alpha Blender Mixer IP block, a time limited sof file is generated fine, but as soon as I use Frame Buffer II, it is not.... Need help on this asap, since I have to advice my boss to buy the IP block or not. Btw, I use Quartus II 64-bit Version 15.0.0 Build 145 04/22/2015 SJ Web Edition. Thanks in advance. Kind regards, Richard.2 Replies
Upgrading to Quartus 15.1 did the trick, I have a time lime limited sof file now.
Thanks for sharing the finding.
