10 years agotime limited sof not generated when using Frame Buffer II IP
Hi, I want to evaluate the Frame Buffer II IP block, but no time limited sof file is generated. The assembler shows the following message: Warning (115003): Can't generate programming files f...
10 years agoUpgrading to Quartus 15.1 did the trick, I have a time lime limited sof file now.
