10 years agoThere is problem in using Avalon MM Master read
I try to use avalon MM Master read.
But there is one problem. "master_read" output can not be one. I attach two figure. One is modelsim wave test and the other is avalon MM Master setting. Thank you! http://www.alteraforum.com/forum/attachment.php?attachmentid=12393&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=12394&stc=11 Reply
and do you also have the implementation? Seems that your signals gets assigned in a wrong way, which leads to an undefined state...
