10 years agoThere is problem in using Avalon MM Master read
I try to use avalon MM Master read. But there is one problem. "master_read" output can not be one. I attach two figure. One is modelsim wave test and the other is avalon MM Maste...
10 years agoand do you also have the implementation? Seems that your signals gets assigned in a wrong way, which leads to an undefined state...
