16 years agoStratix4 PCIE endpoint Hard IP and Avalon ST
In order to throttle the Avalon ST bus, I am using the Valid signal of the Avalon ST Interface from my application verilog module to PCIe endpoint Hardpoint. In this case, my application module wants...
16 years agoI see that this is really old, so maybe this has been figured out by now. Just in case...
I think the problem is related to a requirement placed on the valid signal between the sop and eop. The requirement stated in the user guide is that valid must be continuously asserted b/w sop and eop when ready is asserted. So, if you truly have ready=1 all the time, it is not legal to drop the valid anywhere in between your sop=1 and eop=1 cycles. (Refer to tx_st_valid description in Table 5-4 of the PCI Express Compiler User Guide, version 9.1).
