17 years agoState Machine to Drive DDR Controller works but does not.
I am trying to read and write data to the SDRAM on the Altera DE2 board with Cyclone EP2C35F672C6 I checked the working of the DDR Controller using the example driver. I then replaced the example driver for the DDR Controller with my own State Machine. To troubleshoot - I assigned SW[1] and SW[2] as user requesting read and write. The address is constant and so is the data. Cannot be any simpler, no! :( I write data and then read again. The data I read back is different from what I have written. The problem is - I do not know if read is not working, or write is not, or perhaps both are not. Apparently they both seem to work. wdata_req goes high - and data seems to get written rdata_valid goes high - and data seems to be read But they don't match. I am using the DE2 board, and I followed instructions in here to set it up: http://www.altera.com/literature/an/an380.pdf After setting it up, I got rid of the example driver file and put in my grand state machine that I wish would work. I get errors for the ddr_a pins: Info: Pin ddr_a[0] has GND driving its datain port .. Info: Pin ddr_a[12] has GND driving its datain port (Perhaps because of the fixed addresses?) I am attaching my project (compute.v) is the top level file. It is messy and almost embarrassing to post. --- State Machine Summary--- user_read_req = SW[1] user_write_req = SW[2] State 0: If user_read_req goto State 1 If user_write_req goto State 4 for read: State 1: If local_ready goto State 2, user_read_req=0 Else user_read_req = 1, Stay in State 1 State 2 If rdata_valid goto State 3 Else stay in State 2 State 3 If rdata_valid stay in State 3 (keeps latching data to user_rdata) Else goto state 7 for write:State 4:If local_ready goto State 5 Else stay in State 4, user_write_req =1 State 5 If wdata_req goto State 6 (supply wdata and addr - always set) user_write_req=0 Else stay in State 5 (wait for wdata req) State 6 If wdata req stay in State 6 (keep supplying wdata and addr) Else goto State 7 resting state
State 8Stay here until read and write req are 0. Then goto State 0. ------------- Somebody please help me figure this out. I am stuck on this since forever! What am I doing wrong :(
I forgot to mention: I am viewing signals on Signal Tap.
have you solved your problem? I think I have the similar problem with you. If you have solved your problem, can you tell me how? Thanks a lot
