17 years agoState Machine to Drive DDR Controller works but does not.
Hi, I am trying to read and write data to the SDRAM on the Altera DE2 board with Cyclone EP2C35F672C6 I checked the working of the DDR Controller using the example driver. I then replaced the e...
15 years agohave you solved your problem? I think I have the similar problem with you. If you have solved your problem, can you tell me how? Thanks a lot
