16 years agoSRIO IP clock problem
SRIO IP was generated by megawizar
tow output clocks: txclk and rxclk five input clocks: sysclk io_m_wr_clk io_m_rd_clk io_s_wr_clk io_s_rd_clk Question 1: I connected all of the five input clocks to the txclk, and it seems OK. Is it right? Question 2: If io_m_wr_clk, io_m_rd_clk, io_s_wr_clk and io_s_rd_clk are floating, is it OK? Question 3: The SRIO IP is included in a new projects. Should the srio.sdc file be modified for new projects thank you..No RepliesBe the first to reply
