11 years ago
Simulation time in DSP builder for 512 by 512 image
If i take 512 by 512 image as input in DSP builder then what simulation time i should chose? and what should be the sample time of the image?
    An image doesnt have a sample time.
    Simulation time should be enough to cover the simulation.
    I have block "Image from file" where i have brows an image of 512 by 512 in that case what should be the sample time of the block plz help me..
    "Image from file" this block in Simulink blokset..........
    I have to take convolution of an image with Gaussian filter...........Should i have to add a clock in my design??
    Always best to have a clock block in DSP Builder Standard.
    From what I can make out from the small image, this design would suit the Advanced Block-set well, which will automatically pipeline you design and split adders as necessary to achieve the desired Fmax.
    Yes, the DSP builder advanced blockset will assert just right amount of register to achieve the FMAX, but the design flow has a lot difference with the standard blackest.
