11 years agoSimulation time in DSP builder for 512 by 512 image
If i take 512 by 512 image as input in DSP builder then what simulation time i should chose? and what should be the sample time of the image?
11 years agoAlways best to have a clock block in DSP Builder Standard.
From what I can make out from the small image, this design would suit the Advanced Block-set well, which will automatically pipeline you design and split adders as necessary to achieve the desired Fmax.
