Simulating SCFIFO in modelsim
I am new to HDL and embedded systems in general so i apologise for asking a dumb question.
I created the SCFIFO from the intel IP core. I only used the asynchronous clear, data, q, read and write request. No other flags were needed for my work. I imported the generated verilog files into modelsim. I then created a test bench to drive those signals as you can see below.
I compiled this using the altera_mf and 220model libraries. When, i tried to simulate it, the q (output read data) is high impedance which would suggest that nothing is connected to it, even though it did the port assignments.
Can you please advise me what am i doing wrong?
Thank you
- MuhammadAr_U_Intel
Contributor
your testbench seems correct. so possible issues are.
- library files are missing in simulation, it need to be added to vsim command.
- connections to fifo in the top level wrapper file is broken.
You can share some more details as @Vicky suggested for us to further take a look.
At same time take a look at the simple tutorial for setting up simulation with Native link setup (where all the simulation scripts are handled by quartus), hopefully you will be able to proceed.
https://www.youtube.com/watch?v=PmVVXQchv2c
Let us know if you have any questions.
Arslan
- AKhan15
- Vicky1
Please provide below details,
- have you come across any error while simulation? provide log file/ transcript.
- provide screenshot of simulation window.
Best Regards
Vikas Jathar
- AKhan15
Thanks for the reply.
I think, i've solved the problem. The asynchronous clear in the IP seemed to mess things up. I tried the variant without one and everything was fine.
