13 years agoSimple PCIe DMA
I guess I could try to find the appropriate documentation, but I'll cheat and ask here! I need to find which DMA block to ask our HW team to add to qsys in order to do burst PCIe transfers from...
13 years ago --- Quote Start --- I could manage with physical addresses below 4G. --- Quote End --- Ok (your device driver on the host end would have to deal with it). --- Quote Start --- But my attempts to configure the PCIe avalon MM master that way fail - unless I set the master interface to 64bit - and the dma controller doesn't want to generate 64 bit slave addresses. I can't actually see how the dma controller can actually generate long TLP for reads at all. --- Quote End --- The Qsys PCIe core (which it sounded like you were talking about) does not have a DMA controller. If using the Qsys PCIe core, you would then use a regular Avalon-MM DMA controller on the Avalon bus, which would use 32-bit DMAs to the TXS port of the Qsys PCIe core. This thread has links to documents and code on how that core can be configured: http://www.alteraforum.com/forum/showthread.php?t=35678 Cheers, Dave
