Signaltap on dut|altpcie_a10_hip_pipen1b|test_out[319:0]
Kindly find the updated FTA for the PCIe debugging which is available in Intel Website .
>> click on Debug
- In the 4th tab of the spreadsheet, it says to use test_out to observe PCIe PIPE interface signals.
- you can refer to the 'Diagram' tab in the PCIe FTA excel sheet, which shows a screen shot of 'Expected behaviour for rxstatus, phystatus, txelecidle, txdetectrx' as an example.
For the test out signal, you can ignore it , for the test_in, you should focus on the PCIe IP top level signal, which is 32bit , you can refer to the user guide about it
Hope that able to help you to move forward.
Wincent_Intel
- ALMSlinger2 years ago
Thanks Wincent for digging this out. I had seen this before. Unfortunately, the spreadsheet doesn't say which clock to use to sample test_out. I don't undersand what you mean by ignoring the test_out signal. I want to see what is on the following signals.
So I am asking again - what clock should I use in signaltap to sample these signals?
rxvalid0 1 test_out [86] test_out [246] rxblkst0 1 test_out [85] test_out [245] rxsynchd0 2 test_out [84:83] test_out [244:243] rxdataskip0 1 test_out [82] test_out [242] rxdatak0 4 test_out [81:78] test_out [241:238] rxdata0 32 test_out [77:46] test_out [237:206] powerdown0 2 test_out [45:44] test_out [205:204] rxpolarity0 1 test_out [43] test_out [203] txcompl0 1 test_out [42] test_out [202] txelecidle0 1 test_out [41] test_out [201] txdetectrx0 1 test_out [40] test_out [200] txblkst0 1 test_out [39] test_out [199] txsynchd0 2 test_out [38:37] test_out [198:197] txdataskip0 1 test_out [36] test_out [196] txdatak0 4 test_out [35:32] test_out [195:192] txdata0 32 test_out [31:0] test_out [191:160] Thank you for the help.
Sanjay
- Wincent_Altera2 years ago
I am unable to trace the .stp file, can you please attach the .stp file separately here ?
normally for pcie cases, we suggest to use either
1. dut_coreclkout_hip_clk2. dut|dut|altpcie_a10_hip_pipen1b|coreclkout
3. if not solved maybe you can try out using pld_clk
Can you please try it and get back to me for your result ?
Regards,Wincent_Intel
