host
3 years agoSerial Lite III "start_of_burst" and "end_of_burst"
I'm using the Serial Lite III IP in duplex mode on a Stratix 10 FPGA. In the Tx direction the IP has the following user driven input signals: start_of_burst_tx end_of_burst_tx My mode of work req...
host
3 years agoThanks for trying to help - but you're incorrect.
In my use case - I'm de-asserting valid so by definition I'm using BURST MODE - and NOT continuous mode.
The data I'm sending is NOT "packet oriented" - so although valid isn't continuous my data stream can be treated as a SINGLE INFINITE PACKET.
So in my use case:
1. I have to assert "start_of_burst" (on the first valid).
2. I don't have to assert "end_of_burst" - because my packet NEVER ENDS.
I simulated the design with discontinuous valid and "end_of_burst" tied to GND - and it works fine.
