14 years agoSDI Megacore refclk_rate
In the v11 SDI userguide it describes the new signal refclk_rate with the following:
refclk_rate : Input : Set input 0 for a 148.35-MHz RX serial reference clock and input 1 for 148.35-MHz RX serial reference clock. Ok, so what do I set it to for 148.5MHZ ref clock?:confused: Cheers, Simon2 Replies
i filed an SR on this:
Below statement is the corrected one. Set input 0 for a 148.35-MHz RX serial reference clock and input 1 for 148.5-MHz RX serial reference clock. - Altera_Forum
Thanks! That seems to work.
