JLee25
Contributor
3 months agoVVP Protocol Converter Not work
Hello, I am looking for how to use the VVP protocol converter, by converting Altera Stream Video Lite to Avalon Streaming Video. I generate a simple pipeline with Protocol Converter to Frame Bu...
JLee25
Contributor
2 months agoHi Wincent_Altera ,
I have update on this issue..
I instantiate IP core one by one and it's fine except the VVP protocol converter, LITE to Avalon Stream..
For unknown reason, the Sink side ready always kept now..
Thanks for supporting.
Wincent_Altera
2 months agoHi JLee25 ,
Based on what you provided,
most likely remaining cause is that the MM writes are not reaching the compiled Protocol Converter instance correctly—
for example, wrong base address/offset, incorrect byte addressing, or an inactive control-interface clock/reset domain.
Can you please check from there ?
Wincent_Altera
