MinzhiWang
2 months agoTranceiver Enhanced PCS Basic mode questions
Hello Guys, We used Arria GX and Straitx IV GX devices before, now we switch to use Cyclone 10 GX FPGA. I have several simple questions about XCVR's control port/signal. Why I can't see rx_control...
MinzhiWang
8 days agoHello Ash,
Now we received our new hardware with 10cgx105f780e6s device. You said rx_enh_blk_lock will indicate word alignment achieving. But it only exists on receiver side. How TX knows XCVR link is ok or not?
Ash_R_Altera
3 days agoHi,
In the Cyclone 10 GX Enhanced PCS, the TX side has no built-in lock indicator because the transmitter does not perform word alignment. TX link health is confirmed by the far-end receiver: the remote device's rx_enh_blk_lock (or its equivalent) signals that your TX data stream has been correctly aligned at the other end.
To surface this status locally, implement a feedback path in your FPGA logic that brings the remote RX lock signal back to your local TX domain.
- MinzhiWang11 hours ago
Hi Ash,
Two questions:
- Transimitter can send enough continous BC to ensure tranceiver link properly. During normal operation, for example, 60% time sending user data and the rest time have to send BC. How receiver can know which word is user data or BC (K chractors)?
- Now, we applied one simple test. Transmitter sends constant 32-bit data(h'0008feff), however, receiver receives correct data with MSB-16bit and LSB-16bit reversing, as the following image indication. How to deal with this issue?
Regrad
