HBhat2
Contributor
5 years agoStratix 10 Native PHY PMA register details for reverse serial loopback
Board: Stratix 10 SoC Kit- L-tile.
I am accessing PMA registers to configure the transceiver pairs (GXT) in reverse serial loopback mode.
As per the transceiver user guide:
{0x11D[0], 0...
Deshi_Intel
5 years agoHi HPB ,
Based on user guide doc table A.4.4 - Loopback setting table :
- Encodings {0x11D[0], 0x132[5:4],0x137[7], 0x144[1], 0x142[4]}
- 6'b000000 - Disable reverse serial loopback
- 6'b100101 - Enable pre-CDR reverse serial loopback
- 6'b001010 - Enable post-CDR reverse serial loopback
However, there is also separate note on page 393 that mentioned GXT channel doesn't support reverse serial loopback as well
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug_stratix10_l_htile_xcvr_phy.pdf
- Intel Stratix 10 transceiver channels configured in GXT mode do not support Pre-CDR reverse serial loopback and Post-CDR reverse serial loopback.
Therefore, don't try it on GXT channel else it may end up with weird result as seen by you.
dlim
HBhat2
Contributor
5 years agoHi dlim,
I am aware of reverse serial loopback not supported in GXT speed (More than 17Gbps).
What I mentioned previously is the transceiver channel whichever I am using is GXT capable (In L-tile all channels can not support upto 26Gbps). But, the channels are configured @10.3125Gbps rate.
With Regards,
HPB
