VenT_Altera
21 days agoHi Mikhail_a
Thanks for reaching out.
May I ask the following to help us understand the issue:
- Could you attach the AXI MCDMA .ip file so we can review the parameter settings?
- Which design example variant and which driver did you use?
- Is the issue first observed in Q25.1, then in Q25.3.1? Did it work correctly prior to Q25.1?
- Are you using an Altera Dev Kit or a custom board?
- Could you share the STP when the issue occurs?
- Could you provide the exact steps to reproduce the issue?
Ven
