Dhiraj
23 days agoHi Ven,
It is generated on the user mode BAM+BAS+MCDMA. Please let me know if any other details are required.
VenT_Altera
21 days agoHi Dhiraj
May I know if there are any updates?
Ven
- Dhiraj21 days ago
Hi Ven,
I am analyzing the example design at my side. I will get back to you soon with the updates. Thanks for sharing the information.
- VenT_Altera21 days ago
Hi Dhiraj
Thank you for your reply.
I will follow up with you early next week.
Ven- Dhiraj18 days ago
Hi Ven,
- Yes, I meant a third party customer controller IP which is connected with the MCDMA IP. When you mentioned that we can access registers through System Console, did you mean through HIP Reconfig AXI-Lite Slave? If yes, can it access both PCIe and MCDMA registers and if not, can you please tell through which interface we can access both PCIe and MCDMA registers.
- I have tried by enabling the HIP Reconfig Interface in the MCDMA and tried to access the registers. As per the document, some address range is provided in order to access the PCIE registers. But irrespective the address range I give, the output of the CSR Lite Interface is being driven.. Is this expected?
- I can't find how we can access "PCIe Registers" and "MCDMA-registers" through PIO as its allows host to access on-chip memory (Registers of EP_user connected to MCDMA through user interface). As far as my understanding, we are using some drivers to access the MCDMA registers and the PCIe registers. In this case, internally, which interface is used inside the MCDMA IP to access these registers? Is it still the HIP Interface?
