Derek_Teng's avatar
Derek_Teng
8 months ago
Question about TXS interface of the PCIe IP core (AVMM) for Cyclone 10 GX
Hi
Regarding the txs_address_i[w-1:0] of the TXS interface of the PCIe IP core (AVMM) for Cyclone 10 GX, the user manual states: "Address of the read or write request from the external Avalon-MM master. This address translates to 64-bit or 32-bit PCI Express addresses based on the translation table. The value is determined when the system is created."
In addition, it also states: "Note: The PCI Express-to-Avalon-MM bridge supports both 32- and 64-bit addresses. If you select 64-bit addressing the bridge does not perform address translation."
When I instantiate the PCIe IP core and set the Avalon-MM address width to 64-bit, the parameters "Number of address pages" and "Size of address pages" will not appear. Instead, there is "Address width of accessible PCIe memory space". The value of w in txs_address_i[w-1:0] is equal to the value of the parameter "Address width of accessible PCIe memory space".
My questions are:
When I choose to set the Avalon-MM address width to 64-bit, is the address on txs_address_i equal to the address of the PCIe domain to be accessed?
If so, do I need to set the "Address width of accessible PCIe memory space" to 64?
If I don't set it to 64, then txs_address_i cannot cover the 64-bit address.
If the PCIe core does not perform address translation, how can it obtain the 64-bit PCIe domain address through this address that is less than 64 bits?
In addition, it should be noted that my PCIe address is 64-bit.
  • When I choose to set the Avalon-MM address width to 64-bit, is the address on txs_address_i equal to the address of the PCIe domain to be accessed?
    Yes. When the Avalon-MM address width is configured to 64 bits, the value presented on
    txs_address_i is sent directly as the PCIe address for the transaction. The bridge performs no address translation.
    Yes, if you need to access the full 64-bit PCIe address space, you must set the "Address width of accessible PCIe memory space" parameter to 64.
    If you configure the "Address width of accessible PCIe memory space" to be less than 64, then txs_address_i cannot represent the entire 64-bit PCIe address range. Only a subset of the PCIe address space will be accessible.
    If the Avalon-MM address width or the "Address width of accessible PCIe memory space" parameter is less than 64 bits, so only a partial range of the PCIe address space can be accessed. To access the full 64-bit PCIe address space, both parameters must be set to 64.
    Let us know if you have any further doubts.
    References:
1 Reply
    References:
