Derek_Teng's avatar
Derek_Teng
1 year ago
Question about TXS interface of the PCIe IP core (AVMM) for Cyclone 10 GX
Hi Regarding the txs_address_i[w-1:0] of the TXS interface of the PCIe IP core (AVMM) for Cyclone 10 GX, the user manual states: "Address of the read or write request from the external Avalon-MM mas...
  • TanmayK_Altera's avatar
    1 year ago
    When I choose to set the Avalon-MM address width to 64-bit, is the address on txs_address_i equal to the address of the PCIe domain to be accessed?
    Yes. When the Avalon-MM address width is configured to 64 bits, the value presented on
    txs_address_i is sent directly as the PCIe address for the transaction. The bridge performs no address translation.
    If so, do I need to set the "Address width of accessible PCIe memory space" to 64?
    Yes, if you need to access the full 64-bit PCIe address space, you must set the "Address width of accessible PCIe memory space" parameter to 64.
    If I don't set it to 64, then txs_address_i cannot cover the 64-bit address.
    If you configure the "Address width of accessible PCIe memory space" to be less than 64, then txs_address_i cannot represent the entire 64-bit PCIe address range. Only a subset of the PCIe address space will be accessible.
    If the PCIe core does not perform address translation, how can it obtain the 64-bit PCIe domain address through this address that is less than 64 bits?
    If the Avalon-MM address width or the "Address width of accessible PCIe memory space" parameter is less than 64 bits, so only a partial range of the PCIe address space can be accessed. To access the full 64-bit PCIe address space, both parameters must be set to 64.
    Let us know if you have any further doubts.
    References:
