16 years agoQuestion about simulation of VIP cores
Hi, I'm doing a simulation of Clocked Video Input with Altera-Modelsim using NativeLink, but it seems the IP cores doesn't respond to my testbench as the attachment below, while I have successfull...
16 years ago --- Quote Start --- Hi, are you using a synchronous reset ? It looks to me that in your testbench the clocks starts after releasing the reset. Kind regards GPK --- Quote End --- Hi, GPK As quoted from the VIP user guide, "The MegaCore function is asynchronously reset when rst is asserted high. The reset must be de-asserted synchronously with respect to the rising edge of the is_clk signal." And I have commented the delay for the clocks initial as below, but it still doesn't work. Thanks again! initial begin dclk_in = 0; //#120; forever# 25 dclk_in = ~dclk_in; end initial begin sys_clk = 0; //#120; forever# 5 sys_clk = ~sys_clk; end
