Precise sampling rate and decimation
Hi there, I have spent some time making a MAC based digital 1000 tap filter on a DE1 board. The ADC rate into the filter module is 40khz... However i would like to down sample my data. I am aware of the rudiments of polyphase decimation and that it's strength is; that less computation is used in comparison to simply tossing samples out. But what i really would like to to to call a precise integer value sampling rate. So, if a person wants for example 23Khz sampling rate they can have that. Perhaps I am naive to this but, is the only way to do this to interpolate to increase samples then reduce samples with decimation? If so is this common practice, or is it more common to produce standard sampling rates like, 40k, 20k, 13.3k, 10k, 8k, 6.6K etc..? I would greatly appreciate any creative speculation or any veteran advice:D.
Best Regards H3 Replies
What you want to do is possible but I don't know the details of how to implement it. I've used audio sample rate converter ICs like this in the past:
http://www.analog.com/en/products/audio-video/sample-rate-converters/ad1893.html#product-overview The chip figures out the input to output sample rate ratio from the input and output sample rate clocks and it does this continuously on the fly. This particular chip is limited to input : output sample rate ratios between 1:2 and 2:1. This would be a fun project to figure out. Good luck with it. - Altera_Forum
Thanks rsefton, Ill check it out;)
--- Quote Start --- Thanks rsefton, Ill check it out;) --- Quote End --- you can design "variable rate converter" or call it variable decimator in the FPGA. It is a bit of learning curve. It requires plenty memory for coefficients but only uses few of them at a time.
