9 years agoPrecise sampling rate and decimation
Hi there, I have spent some time making a MAC based digital 1000 tap filter on a DE1 board. The ADC rate into the filter module is 40khz... However i would like to down sample my data. I am aware of ...
9 years ago --- Quote Start --- Thanks rsefton, Ill check it out;) --- Quote End --- you can design "variable rate converter" or call it variable decimator in the FPGA. It is a bit of learning curve. It requires plenty memory for coefficients but only uses few of them at a time.
