15 years ago
PHY Transmission - Arria II GX
I am attempting to send a packet over the PHY (Marvell 88E1111) on my Arria II GX board. I followed instructions on how to generate the correct signals. This is done through a large state machine in which I wait 100000000 clock pulses between sending packets then I put the TX_CONTROL signal high and start sending 4 bits over the RGMII_OUT bus. I first start with the preamble and then the contents of the packets that I would like to send. This is done until the end of the packet is reached where TX_CONTROL is set low and the state machine is paused for another 10000000 clock cycles. I run the state machine at 250 MHz so that 4 bit can be send at both the positive and negative edge of the 125 MHz TX_CLK.
With this state machine I can get the TX light on the PHY to turn on but when I used wireshark on the server attached to it I see no packets coming over the wire. The hexadecimal values being sent over the RGMII_OUT bus are as follows:
555555555555555D
ffffffff
ffffb8ac
6faaa2ed
08004500
006e12fc
00008011
035c0a0a
1a1effff
ffffe490
04bb005a
bbfd0103
80647070
3a2f2f2f
76646361
66687672
36327274
336a6963
6d707832
6e686e75
736b7a35
68736d7a
75793470
75363200
bc09c001
1e1a0a0a
2e00da8f
13693134
2c312c30
2c343736
31000101
1e1a0a0a
1e1b0b0b
Would anyone have an idea as to why this would either not be acceptable to send to the PHY or why the server would disregard this packet so I would not be able to see it in wire shark?
Has anyone else done any work with the Arria II GX transceiver that could lead me in the right direct as to how I can send packet over the PHY?
- Thank you
    Some PC network cards automatically disregard malformed packets or packets with invalid CRCs, so if you have a problem on the packet it could explain why you don't see it in Wireshark. Have a look at the driver properties and see if you can disable any hardware acceleration, CRC/cheksum calculations or error check. Some drivers also show error counters.
    You could also try a loopback test, either by changing a register in the PHY chip or by physically connecting the RX and TX pairs on the network connector. Then you can have a look at the RX signals and check that what you receive is exactly what you sent.
    Are you sure that the PHY negotiated correctly a gigabit connection? Are you using a DDR I/O block? In that case are you sure that you use correctly the high and low inputs and are sending the 4-bit words in the right order? Did you properly constrain the RGMII interface and does your design meet all timing requirements?
    I looked into this problem further.
    --- Quote Start ---
    --- Quote End ---
    Viewing netstat through the command console I found that when the Arria II GX development board is transmitting the discard count increases at the same rate of transmission so the packets must be malformed when they get to the computer somehow. I cannot see anyway to turn off CRC/checksum or hardware acceleration but I am reading the reference manual. The NIC is a Broadcom HP NC373i.
    --- Quote Start ---
    --- Quote End ---
    I have done a loop back test in hardware where I send the exact same bit sequence from input to the output but this programs packets are also recorded as discards.
    --- Quote Start ---
    --- Quote End ---
    In terms of the PHY negotiating correctly the Gigabit light turns on which I assumed indicated correct negotiation although I could be wrong.
    I'm not sure what you mean by a DDR I/O block but I did try the altddio_out megafunction described in the timing in the altera an477 documentation.
    The megafunction never worked so I created the necessary timing by hand using PLL and state machine. These are the timing requirements I followed for the current program I am testing.
    I have tried the bit order in both ways for a sample packet but have gotten rx crc errors in both cases. Does the bit order matter if I am not using a DDR I/O block?
    What exactly didn't work in the ddr i/o megafunction? Maybe we should start by looking at that.
    Did you put timing constrains on the RGMII interface? Does the design meet all timing requirements? he PHY chip can be configured with a 90 degrees clock shift to read/write data at the clock center instead of the edges, by using a special MDIO register.
    I followed the RGMII interface specified by Altera more closely and I have a receive and transmit unit working. The ALTDDIO_IN/OUT work very well for this. Also the timing of the TX clock was still shift by 90 degrees.
    The only thing that remains is how to make a better basic receive interface? I found that using different equipment preambles vary and even just checking for the preamble itself doesn't work 100% of the time. Do you know of any basic receiver that work very well besides the Altera TSE MAC?
    The preamble length can vary, depending on the time the PHY needs to lock on the incoming clock, but it should always finish with 5D. If it doesn't, you may still have a problem with your RGMII input, possibly a timing problem.
