16 years agoPCIe Transmission Problem
Hi, I have the Altera Stratix II GX Dev Board. Im' using the Altera PCIe 9.0 IP Core with Avalon-ST Interface and I ran into some problems. I transfer 4 MB of data in 128 Byte blocks +...
16 years agobtesar,
The issue that I ran into was system related. The application hardware that I was testing was trying to write the same system address over and over, so the memory controller appeared to be holding me back, as opposed to PCIe. When I switched to a more realistic use case, I saw my transmission rates recover.
