16 years agoPCIe Transmission Problem
Hi, I have the Altera Stratix II GX Dev Board. Im' using the Altera PCIe 9.0 IP Core with Avalon-ST Interface and I ran into some problems. I transfer 4 MB of data in 128 Byte blocks +...
16 years agoJust in case you are still struggling with this problem, and to inform others who might expierence a similar problem.
The PCI Express specification states that when a malformed TLP is received, flow control information does not have to be updated. Therefore after a few malformed TLPs the transmitter will run out of credits, blocking any further transmissions. You should check if the TLPs you are sending accord to the specification.
