17 years agoPCI Express:Max_payload_size and lane width
i have design a X4 pcie endpoint device based on Quartus pci express ip V7.2. when i plug the device to the x16 pice slot of my dell optiplex 620 host, the device can only be recognized as an ...
17 years ago --- Quote Start --- The 128B is typical limited of the root complex chipset. Check the motherboard chipset datasheet to confirm. --- Quote End --- it is mean that if the root complex only support max_payload_size of 128B ,then at the configure cycle, it will change the EP device's control register to set it's max_payload_size to 128B,right?
