16 years agoParallel Flash Loader function
Hi, I'm having a problem with the PFL (loader only) function. With the design compiled under Quartus 9.x, the programmer reports unable to connect to the flash type error. Same design compiled wi...
16 years agoClearly, if the configuration data is read from the flash is incorrect, configuration will be aborted soon. So I would check, why it apparently isn't programmed correctly. Check the timing against the P30 specification and the data against a configuration raw data file.
