16 years agoParallel Flash Loader function
Hi, I'm having a problem with the PFL (loader only) function. With the design compiled under Quartus 9.x, the programmer reports unable to connect to the flash type error. Same design compiled wi...
16 years agoI used PFL with Spansion rather than Intel flash, so I don't know, if there are particular issues. AN386 says, that only 28F128P30 has been actually tested, the others should work according to their CFI compliance.
If you didn't modify the PFL design, I would primarly expect a hardware issue, e.g. wrong flash wiring. I understand that you wired the flash to MAX II and FPGA in parallel. I hope, this doesn't bring up problems. As you reported, that the flash isn't programmed by the PFL when it should, I would start checking the flash signal during programming sequence with a logic analyzer or oscilloscope. Running the PFL on the FPGA, you can also use SignalTap.
