16 years agoPAL Clocked Video Out with Embedded Sync
Hi, I am trying to get a PAL output form the clocked video out core using embedded sync. This is supposed to be fairly straight forward, but for some reason I just cannot get it to work. My ...
16 years agoHi Jake,
Yes, the test pattern generator is setup to output an interlaced frame. I am not 100% sure if the I need to divide the framwe height by 2 (i.e. 288 instead of 576). Also, on the CVO, I am not sure if I should divide the frame height by 2. The default parameters for PAL does not, so I assume it is not required. Regards, Niki
