15 years agoOverlay moving (live) graphics feed on video
I need to mix a live graphics image (Streaming into the FPGA) that has a special pixel value in places where VIDEO should show through. I know that the Alpha Blending Mixer can do this, if I can sample the graphics stream and create an ALPHA Channel with it.
I need to see how to use the alpha channel (I can't find any examples) and use this data to enable the underlying video to overlay the graphics on a video stream. Thanks, in advance. Mike3 Replies
try this for liminance.
output = pixel/256 *(256-alpha) + graphics/256 *alpha As for chrominance - good luck. It might be easier to convert it all into the RGB colour space before mixing if you want to mix in colour. - Altera_Forum
--- Quote Start --- try this for liminance. output = pixel/256 *(256-alpha) + graphics/256 *alpha As for chrominance - good luck. It might be easier to convert it all into the RGB colour space before mixing if you want to mix in colour. --- Quote End --- Thanks, but I need ti create the alpha channel and I also need to see an example of how to connect the alpha channel in SOPC. MIKE - Altera_Forum
have the same problem:
i need to configure alpha blending on DE2 without using CPU I've found some information about Alpha Blending Mixer over google with next request: alpha blending mixer sopc example but in every manual NIOS processor is used does anyone have sth much useful, like working examples?
