16 years agoonchip RAM resource usage
Hi all I'm using a cyclone III EP3C40 device which boasts 126 M9K blocks for over 1Mbit onchip RAM. I understand that 'real' memory bits are 8/9, so I have almost exactly 1Mbit. My former des...
16 years agoThank you for your answer, Tricky
You are right. I explored the fitter report and found out: Total memory bits: 618472 ot 1161216 (53%) M9Ks: 122 of 127 (97%) These are the ip modules using M9Ks in my design: - Nios II/f with cache - clock crossing bridge - 4 onchip memory - 2 tse mac - 2 sgdma - epcs and jtag controllers If I understand correctly what you said, even if Quartus reports a device utilizing only 40 memory bits, actually it requires a whole M9K block, then 8kbits ! I discovered tse and sgdma modules contain plenty of such devices. Can I overcome this situation? I believe I once saw somewhere an option forcing synthesis of memory into registers rather than M9K but now I can't find it any more. Is this possible and safe? Thank you Cris
