17 years agoNeed Help For Learning Sd Card Ip Core
Hi, I want to make a SD CARD SPI MODE Host controller. I tried to make it using vhdl code only. But in the middle of it , I realized that it was to complex without using SOPC builder and NIOS II. Since ,I'm new using iP core. I don't know how to start.
I'm already search in the web for any example SD CARD IP Core, but 'till now it's all not free :( . Please if anyone can help me ?7 Replies
may be this can help you: http://www.niosforum.com/pages/forum.php?cat_id=5 Regard Luca - Altera_Forum
when i build the project in the NIOS IDE,there are some errors:
**** Build of configuration Debug for project hello_world_1 **** make -s all includes Linking hello_world_1.elf... /cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.text+0x54): In function `alt_sys_init': system_description/alt_sys_init.c:92: undefined reference to `sd_controller_dev_init' /cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1144): undefined reference to `sd_open_wrapper' /cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1148): undefined reference to `sd_close_wrapper' /cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x114c): undefined reference to `sd_read_wrapper' /cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1150): undefined reference to `sd_write_wrapper' /cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1154): undefined reference to `sd_lseek_wrapper' /cygdrive/e/sopc/sd/sopc_soft/software/hello_world_1_syslib/Debug/libhello_world_1_syslib.a(alt_sys_init.o)(.data+0x1158): undefined reference to `sd_fstat_wrapper' collect2: ld returned 1 exit status make: *** [hello_world_1.elf] Error 1 Build completed in 85.875 seconds How can I solve this problem? Thank you. - Altera_Forum
Hi quray,
sd_controller_dev_init'sd_open_wrapper'sd_close_wrapper',etc Is it a function ? If it is a function please check Have you already include the .h file that describe the function ? I'm new in here but i'll try my best to share my experience.:) - Altera_Forum
Than you very much.I have solved this problem.
sopc builder in Quartus 8.1 is different from Quartus 6.1 . in \neek_alternate_sd_card_controller\sd_card_controller_component\SD_Card_Controller_SPI\HAL\src create component.mk ,and add # This file generated on 2006.03.22.10:57:43 C_LIB_SRCS += sd_controller.c\ fat.c\ fat_file.c ASM_LIB_SRCS += INCLUDE_PATH += # end of file in this file. http://www.cnblogs.com/oomusou/archive/200...mponent_mk.html (http://www.cnblogs.com/oomusou/archive/2008/12/06/ip_component_mk.html) - Altera_Forum
hi,Luca Olivero, u give the web can not connect,i also want to learn about how to use the sd card.
Hi,I P,
can u post me some files about the sd card,i also use the sopc builder to use the sd card. thanks! - Altera_Forum
Hi,I P,
