17 years agoNeed Help For Learning Sd Card Ip Core
Hi, I want to make a SD CARD SPI MODE Host controller. I tried to make it using vhdl code only. But in the middle of it , I realized that it was to complex without using SOPC builder and NIOS II. Sin...
17 years agoThan you very much.I have solved this problem.
sopc builder in Quartus 8.1 is different from Quartus 6.1 . in \neek_alternate_sd_card_controller\sd_card_controller_component\SD_Card_Controller_SPI\HAL\src create component.mk ,and add # This file generated on 2006.03.22.10:57:43 C_LIB_SRCS += sd_controller.c\ fat.c\ fat_file.c ASM_LIB_SRCS += INCLUDE_PATH += # end of file in this file. http://www.cnblogs.com/oomusou/archive/200...mponent_mk.html (http://www.cnblogs.com/oomusou/archive/2008/12/06/ip_component_mk.html)
